Port length calculation
  • 2
TonWardHD
CarAudio.com Recruit
33
Hey. I’m using winsid 0.7 to determine my box dimensions and it says my port length should be 29.4 inches. So I doubled check with 3 websites and two say 25.47” , while one agrees with winisd and says 29.4”
what do you guys use to accurately calculate this?
EDIT
On winisd it does not let me choose slotted port. Only circular and square. All websites agree now that with a square port it should be 29 while the same ones that have the option for slotted port agree with 25.4.
should I not listen to winisd’s length for square port and follow these other websites calculations for slotted?
***im using slotted by the way
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
697
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
870
TonWardHD
TonWardHD
THATpurpleKUSH
    May 18, 2024
    May 16, 2024
