port noise
JoshGuy
i have port noise from a 4 inch pipe port i made... i went to calculator and figured out that if i get my port up to 6 inches i should be fine and there wont be any more noise. But i was wondering can i leave my 4 inch port and and instead just add another 2 inch port or will that still have noise?
4" port + 2"port does not= 6"port.
---------- Post added at 11:35 PM ---------- Previous post was at 11:34 PM ----------
how big is your box?
Its 5.54 cu ft after displacement. i figured it needs to be a total of 20inches of port if i use another 4 inch port. but if i add a 6 inch instead it only needs to be about 10 inches
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
800
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
981
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
957
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
JoshGuy
JoshGuy
Lawton, OK
agarabaghi
