port size
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 1K
  • 1
U
Unregistered
Guest
ok...i just bought a ported closure....in the instructions it says to cut to ports to desired length..i want a lower bass comin outta the ports...do i cut them short or keep them long....??
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
843
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
991
Guest
zane
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
