Port too small?
How tall is the port and how big is the box a buddy locally built a small box 1.25 with a 1"wide 15" tall port for an sa12 and it sounded good no port noise.
if the port is 14in tall it should be fine, if its 11.65in tall that is on the small side. Also port location in the vehile will also determine port noise. In trunk your not gonna here it but in cab you may need to make sure you have enough.
If using a decent sub, double the width to 2". Then re-figure the needed port length, and redo the design so that you still have the same net air space after all displacements.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
840
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
987
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
45js45
45js45
lost.....again
RAM_Designs
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
