Possible blown 13W7 ?
You can test a sub free-air with a cordless drill battery. If it moves and it doesn't scrape, it's good.
What you're probably hearing is your home receiver falling on its face when tasked with running a reactive load like the W7. Some amps just can't hang and don't have the current capabilities to run something like that woofer. What happens here is that the signal gets all screwy and causes the sub to make some really strange noises. This is different from straight up clipping/overdrive and will not sound the same.
To complicate matters even more; a poorly sealed box or improperly engineered vented box can exhibit the same symptoms.
Onkyo Integra's are only rated down to 4ohm... also.. I have never seen one with a sub out other than low voltage RCA.... so... could you be giving it a full range signal?.. would make sense that it sounds terrible and scratches..
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
633
Hmm.. No Bueno. Id prob be looking at another set of subs to be honest. Like some American Bass DX series. Great subs for the $. Maybe even look...
8
900
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
11
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
asr10 user
asr10 user
Los Angeles
teamquakecelica
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
