powered sub needs a seperate wire to battery?
  • 4
usenet4life
12
gta, on
I am thinking of purchasing either the
Audiobahn ATB8AT
http://www.crutchfield.com/S-7FjXF49poqO/cgi-bin/ProdView.asp?g=51000&tab=detailed_info&i=037ATB8AT#Tab
or
Kenwood KSC-SW1
http://www.crutchfield.com/S-7FjXF49poqO/cgi-bin/ProdView.asp?a=&s=0&cc=01&g=51000&id=review&i=113KSCSW1&pg=6&sortBy=3
I thought that powered subs needed to be connected to the positive terminal in battery. Looking in the manual for the Audiobahn confirms this, but the manual for the Kenwood does not show a connection to the positive terminal. Is this correct? I will get the Kenwood then as I don't have to fish the wire through the firewall.
http://img384.imageshack.us/img384/2405/batteh1.gif
Looking at that diagram for some incredibly stupid reason they are showing running the yellow power wire to the HU?!?
That yellow wire with its included 10a fuse needs to be powered by a connection to the battery I would wager...
impreza wagon. the kenwood is small enought that it will fit under the front passenger seat.
It may not be hard to drill a hole but I want to use an existing one.
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
441
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
usenet4life
usenet4life
gta, on
usenet4life
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
