Powering a single sub with a 4ch amp
  • 3
Josh_101
It was something that popped in my head. I was looking at the newly listed Alpine PDX amps on woofersetc, and the 400 watt 4ch model caught my eye, mostly because of its lower price. Is it possible to run one dual 4ohm sub connecting all 4 channels to all 4 voice coil terminals (since the amp is rated 200w x 2 at 4ohm bridged) as long as the adjustment screws and x-over switches are set at the same position?
It should work fine. Bridge each pair of channels to each coil.
Back in the good old days before amplifier strapping, I knew people who ran two amplifiers per dual voice coil subwoofer. One amp per coil...
D4 sub? I don't see why it wouldn't work
Yeah I was thinking it through in my mind, the impedance rating matches, if gains are set at a matching output, maybe that wouldn't hurt anything. My two eD 8's are getting a little noisy from beatin the crap out of them for the past year. The PDX amps caught my eye because of their compact design and ability to be stacked together easily. My amps are stacked together but it was a PITA to make it happen, and I dont really like how it looks currently.
I'd like to get the SI BM 12" shallow sub, but it only comes in dual 4ohm, so my 2ch 400w amp isn't going to work well for it being that it only makes that much power at 4ohm bridged. The box size I'm limited to (.5cf) is the perfect size for that sub too.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
860
My experience says that for most people, usually, overpowering subs doesn't really gain much, especially for daily or music. Actual power levels...
5
835
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
When you say power on for a limited time, do you mean power after the vehicle has been shut off or just turning on the radio and it plays for a...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Josh_101
Josh_101
E.C. North Carolina
Josh_101
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
