masonstephens55
CarAudio.com Recruit
i have a 1500w amp and a 3000w rms sub. would it be safe to run it like normal or do i need to upgrade to the 3000w amp?
What amplifier do you have? Make and Model? What Subwoofer do you have? Make and model? What type of enclosure is the subwoofer in? Dimensions? Ported/ Tuned to? Sealed? What size and type of power and ground wire are you using? OFC or CCA?i have a 1500w amp and a 3000w rms sub. would it be safe to run it like normal or do i need to upgrade to the 3000w amp?
You'd be louder with a 3k but you can run it as isi have a ct sounds CT-1500.1D // 1500 Watts RMS Monoblock Car Audio Amplifier and my sub is a Avatar STU-1546 D1/D2 3000w RMS 15" Subwoofer. my box is tuned to 34hz and ported. Im running a big 3 0/1 gauge kit and 4 gauge wire to my amps for both ground and power.
Set your gain to the hu voltage...how do i keep from clipping?
DVC1 or DVC2 ohm sub?i have a ct sounds CT-1500.1D // 1500 Watts RMS Monoblock Car Audio Amplifier and my sub is a Avatar STU-1546 D1/D2 3000w RMS 15" Subwoofer. my box is tuned to 34hz and ported. Im running a big 3 0/1 gauge kit and 4 gauge wire to my amps for both ground and power.
