Powering speakers with different power ratings
notactiveuser
CarAudio.com Newbie
oz
Hello, I have two Kicker 6x8" CS series speakers that are rated at 75 watts RMS 225 watts peak, and two Kicker 6x9" CS series speakers that are rated at 150 watts RMS and 450 watts peak. My question is how do I properly power all four speakers with a single 4 channel amp? They are 4 ohm speakers so could I wire the two 6x8"s at 4 ohms into their own separate channels to get the standard rated power output per channel and then run the two 6x9"s in parallel to one channel to get more power in a 2 ohm impendence? That is the only idea I have so far but I don't know if that is correct. I am trying to do a low budget setup in for my Mercury Grand Marquis. Thanks.
RMS power ratings are not the exact number required. RMS means Root Mean Square. It is the "point of efficiency". Speakers can usually take more power. Some speakers can take a lot more power. You are just adding more power and not getting an equal return on your decibel/volume. Its a curve that is spiking after RMS for power usage, but giving very little return on any improved performance. (EX. If 150watts is your given RMS, and it gives you 95 decibels, 200 watts might only give you 96 or 97). It's generally doable, it's just not usually worth it.
When you start factoring in how amperage draw, and upgrading alternators, batteries, wiring, electrical overall, you can step it up to a level that is not worth it. That's just not a concern for what you are wanting to do. It's really a question of whether the speakers can handle it. Any number given to you for peak power is rated at full volume (when your gain is set properly) for quick bursts. If you don't listen to your music at full volume, then you would be okay. I searched and those 6x8s are 75w RMS and 225w peak. I would feel comfortable running those at 150w.
Running two speakers on one channel will either make them run on the same side, or make them run in mono. I would avoid that for anything other than subs.
I would just use a 150w x 4 amp, and you should be fine.
Are the 6x9s in a decklid, and the 6x8s in the door? You could see if getting an adapter (if you even needed one) will work, see if you can trim the sheet metal or whatever is there around the mount, and get a second set of matching 6x9s to fit where the 6x8s are going to go. (You already have one to test fit). If it does, you can run the 6x8s and have a backup plan.
If it's in the budget and you considered one. Now would be the time to look at 5 ch amps if you wanted a subwoofer. A 5ch amp could be right there in price where it could be cost effective with a 4ch amp, when adding a second sub amp isn't. Not buying a second amp, or not having to run extra wire, or distribution blocks can save a little on the overall setup cost.
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
634
My experience says that for most people, usually, overpowering subs doesn't really gain much, especially for daily or music. Actual power levels...
5
771
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
6
When you say power on for a limited time, do you mean power after the vehicle has been shut off or just turning on the radio and it plays for a...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
notactiveuser
CarAudio.com Newbie
notactiveuser
oz
HardofWhoring
1aespinoza
    May 23, 2024
Doxquzme
    May 22, 2024
