Problems with a JVC unit
  • 2
Zigaziv
Hey. Ive been killing myself trying to find the answer on the internet but havent found any so far.
Here is my problem:
I have a JVC stereo that i bought a few days ago. Ive instaled it and averything was working perfectlly. But after a few days (3days) I was driving home from work and the radio sudenlly shut itself off. Since than the radio only works if the ignition is in the off possition. As soon as i turn the key to ACC/Start engine the radio shuts off. Somtimes it shuts off fast and some times it seems like it fades away. Ive looked at all the fuses and ive checked the wiring( tried all the yellow/red wire combos and nothing helps) The car is a Golf 3 1998. If u need any other info Id be glad to give and i hope someone has an idea what the problem could be cuz its starting to drive me nuts
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
759
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
811
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
Zigaziv
Zigaziv
Netherlands
Zigaziv
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
