Professional opinions needed about installation/electrical ugrades!
  • 4
I have a 1999 Chevrolet Suburban. I have 2 15 inch Kicker CompVRs powered by a Kicker ZX 1500.1 amplifier. I am having a problem with my system cutting out. I have already fried the MOSFETs in the amp once. I know that my problem is that I'm not getting enough power to my amp. So my question is what is my best option/s to increase my electrical supply to my amp so I can see how hard my system can truly hit. I would also like someone's opinion on making the choice between a Super Bass Pro Box or a Custom built box that will be designed and constructed to the actual specifications recommended by Kicker.
Get the custom box you'll be better off The electrical needs a ho alt. 200 amp + and an extra battery even a small one. Our trucks stock electrical sux
start with the big 3 and then go from there. a 1500w amp is not a huge strain on a stock electrical system once you factor in rise. Also make sure you have the settings correct. An incorrectly set gain can cause many issues
Different companies do the loudness at different levels. The one that you have would probably have sounded pretty good on factory speakers and...
7
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
8
935
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
Ike_Turner
Ike_Turner
Hattiesburg, MS
csu87
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
