I have a Taramps 8k 2 ohm on the way, reading up people say you cant use the root mean square method to estimate power, but this thread says clamping can still get you far off from "true power".
I have a dual trace o scope, dmm, and an AC fluke amp meter. Should I just use the clamp method?
What is the best way to set gains on a taramps, my searches don't pull anything up.
With rise, 20-ish hz and 35-50hz the power is def gonna be reduced (2 ohm zv4). With the box being tuned to about 30, should I clamp the wanted rms at 30hz?
