Question on subwoofer wiring
  • 1
SilveradoKicker
Oklahoma
Ok...I have 2 4 ohm dual voice coil subs...the kicker comp cvr124's...anyways i had a professional install these subs in my single cab truck because there is no way that i could have done it myself...they are in a dual 12 inch sealed box...and they have the plus and negative click things on both sides...but this is were i get confused on the drivers side I have a wire that comes off at the end into 2 and 1 goes into the positive and 1 goes into the negative...but then on the passenger side i have two wires and 2 go into the positive and 2 go into the negative...which doesnt make since to me because there the same subs...but the problem is the other day i was vacuming out my truck and i accidently hit one of the wires out on the passenger side and i thought it was as easy as plugging it back in the hole...but both my subs wouldnt play so i didnt know what to do so i tried every combination of hooking the wires back in on the passenger side and both of them still wouldnt play so i dont know what is wrong i guess im just not smart enough to figure out how they were plugged in there...but if anyone understands anything about what i just typed please help me...thanks alot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No. Those are speaker level inputs from the subwoofer. Lower frequencies should go to the subwoofer. The other front and rear speakers carry a...
10
Haven't 100% landed on which one, but I am down to those two
I'm still in the process of tuning my system, and it won't be fully finished until I build the enclosure for the pair of 18"s. I tune my substage...
36
5K
Conventional wisdom holds that you're looking for Qts of .7 for good "flat" response. Smaller box will give you higher Q which can give you...
If this amplifier is an aftermarket unit, it should have RCA Output. If it is not, then connect to the rear amplified speakers. The sub amplier...
SilveradoKicker
SilveradoKicker
Oklahoma
SilveradoKicker
    Jun 1, 2024
    May 31, 2024
