Questions about using a DMM
502CEC
I would like to get some info as to how and what all I can test with the digital meter. I see people on here talking about using meters to check the output on their amps, to check their grounds, and to check their VC on their subs, and I'm sure there is more things. So if anybody knows how to explain how to do any of these test or more please explain. Thanks
To test for impedance switch the multimeter to the omega symbol Ω. Red test lead goes to the positive terminal, black goes to the negative, obviously.
To test for output, or to set your gain, you switch the multimeter to AC voltage (shown usually as a sine wave). Check for power going to the amp or for a faulty ground, switch your meter to DC voltage (shown as a line with a dotted line above it). You can also switch your meter to continuity to check and see if a circuit, voice coil, or fuse is blown. No need to match up leads, just put them in the 2 spots you want to check and the meter should make a beep noise. Don't check for continuity if a circuit has power running through it though because you can short it out with the leads and blow a fuse in the meter.
As for testing how much an amplifier actually puts you would need a rms clamp meter which operates differently than a multimeter does.
Everything said above is a good starting point.
While that is not untrue, there are plenty of threads on this site for setting gains using a DMM. While is not as perfect or easy as clamping to get the power output at a specific frequency, it is close enough to properly set the gains.
To set the gains with the meter should the radio be turned up or does it matter. Or is the goal to just get the #'s from amps to match on the meter. Also now that I know the settings for the meter what type of reading should I get when tryin to test my ground?
These 2 sites will pretty much answer any questions you have about basic/intermediate car audio:
Basic Car Audio Electronics
Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers
Between the articles, charts, and diagrams, you can look up this info very quickly.
Yes, the radio needs to be turned up to measure the power output from your amp. You are measuring how many volts are coming out of the amp, and using a chart you can convert the volts @ ohm load over to watts output.
These 2 sites will pretty much answer any questions you have about basic/intermediate car audio:Basic Car Audio Electronics
^This, especially Perry's site, Basic Car Audio Electronics...that site rocks.
He wasn't talking about setting the gains at the point, he was referring to actually clamping how much power the amplifier can produce. Just because an amplifier is rated at a certain ouput doesn't mean that's it's exact output, it always varies but if you have a current clamp you can calculate the actual output. Although this reading is practically useless without also measuring THD.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
558
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
6K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
502CEC
502CEC
Frankfort KY
bubbagumper6
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
