Questions on sub and amp wiring
  • 4
Hash4040
CarAudio.com Newbie
Iowa
I have 2 12 inch type r r-w12d2 subs I need to buy a amp and I want the best possible setup. Do I get mono or 2 channel and are the subs 1 ohm capable. If so what ohm amp do I buy and how big. I have them in a vented enclosure also.
Looks like you can go series/parallel and get to 2ohms or 8 ohms in series...
something that does about 1200-1500w at 2 ohm will get you were you wanna be
Wire to the final 2 ohm load as detailed in the 12v wiring diagram. Unless you have the electrical to back up the 0.50 Ohm load and the Taramps 0.50 stable amplifier. Running @2ohms mono will slamm just fine if the subs are in the properly tuned enclosure for the environment placement/vehicle and your electrical can provide the supply for the demand. I run @2ohms mono atm and very happy with my results. I always get asked what type of 15s am I running, and to theyre surprise its a pair of heavy tens slamming the ride at the moment. Type R subs are really great subs. I think you will be very happy with them fed properly. Just some amplifier recommendations. Whats is your Budget for a mono amplifier? Recommended to run a mono amplifier on sub duty for great results
Amazon product ASIN B0BZJXRNXY
Amazon product ASIN B09TFZH1HW
Amazon product ASIN B09YVT2P89
Amazon product ASIN B07Y3TK3CS
two d2 subs can be wired to .5 or 2 or 8 ohms
not 1
heres how to wire subs...
id probably get this amp...
You,sir, were correct. I was concerned more with going from ported to sealed, but these two 12s do very well. Less drain on the electrical, less...
990
Not saying it can't be done or will necessarily sound bad and have heard reliable sources say they've had it sound good. I just never sat in one...
11
Sure we need to grow up, ok. I gave you the exact answer then you blew up on me saying I was wrong. Time for self reflection bud. Cant take...
20
3K
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
390
Hash4040
CarAudio.com Newbie
Hash4040
Iowa
nauc
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
