Quick port area/volume question
  • 2
BTF
CarAudio.com Newbie
23
Oklahoma
If EVERYTHING else stays the same, does port area and/or volume need to be different for different amplifier powers? In other words, if I change from a 1000W amp to a 1500W amp on the same sub, will I need to change any box parameters?
It would be a good idea to check the port velocity and cone displacement for the new power level.
The extra power will push the cone further which can exceed the physical limits of the driver.
If port velocity is too high then the port will need to be enlarged, which means it will need to be longer to maintain the same tuning, which displaces more volume in turn shrinking the volume, requiring the port to be even longer.
See where that is going?
Thanks Kush! I modeled it in WinISD and at 1500w, port velocity is under 21m/s and excursion reaches max under my subsonic cutoff frequency, so I should be okay, right? Or will the rolloff at cutoff be too slow and cause issues?
Here’s a link to a post on the SSA forum, but no one has responded. If you or anyone else wouldn’t mind looking at the WinISD graphs I posted and give me some feedback, I’d appreciate it!
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
962
i have no experience with component speakers. Maybe someone else can help in this area.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
BTF
CarAudio.com Newbie
BTF
Oklahoma
BTF
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
