radion reception on Kenwood 516s
  • 2
BigDave
I just bought a Kenwood 516s and had it installed in my 02 Isuzu Trooper. The Trooper has the antenna integrated into two rear windows. On the factory unit, reception is great. Now, at best, I get fuzzy reception from local stations. There is no reception of stations over 30 miles away. The unit was installed by the store I purchased it at. Does anyone here have any ideas or experienced any other related issues?? Thanks in advance!
I am not positive, but you probably have a diversity antenna in the windshield of your trooper. the only thing I can suggest is running wire to an antenna that you install to the fender or maybe a fuba whip (like some vw's come with) on the roof..... or try getting a small fm antenna booster I wish i remembered the brand of the one we used to sell because I was impressed with the stations that came in after it's install....It was small no larger than 2"x4"
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
I know this must be a simple fix! But can't work it out! When the head unit is out of the cage/holder the radio and DAB reception is perfect. As...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
395
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
959
BigDave
BigDave
Midwest
gregj9
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
