wiring 4 JL w3 10s
  • 1
go to rockfordfosgate.com and then go to rftech scroll down a little and pic wiring wizard. you can then select a bunch of **** pic the one that says 4 woofer system 4ohm dvc 2ohm load this will show you how to wire it. how this helps
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
112
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
364
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
357
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
672
cmd343
cmd343
Maurice, LA
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
