Rca failure
  • 3
lifesproduct
What causes an amplifiers Rca inputs to fail? I have a hard headed buddy that has messed up the inputs on 2 different hifonics amps. I have a feeling it is user related, but I have never seen someone have so many issues with the rcas before. Thanks in advance
His first was diagnosed from the shop he bought it from. The 2nd will play normally if you toy with the inputs on the amp. We have also replaced rcas, swapped head units, and check all connections in and out of the box
Most common failures are due to mechanical stress and vibration. Most RCA jacks are PCB mounted and not mechanically anchored to the chassis itself. So it is just the solder and circuit board pads that hold them in place.
If you push too hard on the RCA you can lift a pad or crack a trace.
If the amp and RCA cable are not mounted solidly together then over time vibration can pop a pad or crack a trace as well.
So 1) Do not push too hard when making connections and 2) anchor cable to amp and amp to car very well.
Less common is an electrical failure due to ground currents flowing through the RCA shield connection due to the amp, head-unit or other device in the chain not being properly grounded.
Crappy cables would be another failure, but not really a failure of the amp input itself.
I think that just about covers it.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
865
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
896
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
756
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
847
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
942
lifesproduct
lifesproduct
Rochelle, Ill
lifesproduct
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
