RCA to 5-channel
  • 2
nathansadkins
US
So here's the deal...
I bought a new head unit and installed it into my accord (Pioneer MVH-X380BT) and was planning on buying this Pioneer GM-D9605*5 channel amp. I also bought two new Alpine 6.5 and 6x9s and haven't decided on a sub yet. My head unit has one set of RCA cables and I have been trying to figure how to connect that to my amp but out but haven't had any luck. I went on a forum and all I could find was this:
"Unfortunately your head unit doesn't have a full-pre-amp section so in this case you'll need to wire right to the amp output for front/rear signal. You can turn the RCA output on the Pioneer into a subwoofer pre-amp though, and use RCA for that connection." Could someone tell me if this could work? Thanks for any advice.
Sent from my Nexus 5X using Tapatalk
You only have 1 rca from the headunit? You need to plug it in the front rca and flip the input switch,then flipping the sub input switch to a/b.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
867
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
897
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
756
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
848
nathansadkins
nathansadkins
US
pickup1
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
