RCA's
  • 2
OK if I'm running two four channel amps and 1 mono and I already have 1 set of 16ft 4-channel RCA's and two 16ft 2 channel RCA's, how many do I need if I'm running a DSP (PPI 88r) with 2 in 8 out?
You need one more channel unless you will bridge at least one pair of full range amplifier channels. How many speakers are you running?
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
665
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
667
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
584
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
754
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
889
dailyrider123
dailyrider123
under the sun
dailyrider123
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
