Rcas
  • 6
Bass so loud it HZ
CarAudio.com Regular
I had a set of rcas go out a couple days ago so I changed them put with a cheap set I had laying around but now my clip light is coming on on my amp when I used to be able to play the exact song volume everything and it wouldn't clip .i didnt notice it at first. Has anyone ever had this happen or could it be something else
You are most likely getting a stronger signal now with a newer set of RCAs and may have to adjust your HU-amp Voltage again, and may even need to Retune as well
Alright thanks man . Never thought of it like that. The old set was t spec so they were good the set I'm running now is I think the blue Walmart ones lol it will get me by till I get a better set lol
Just installed some Sky-High OFC RCA's for the price they are decent and definitely better then the so called Memphis OFC I had in there before. Did a 4 channel set of them and even the install bay 2 channel set I used for now for the mono-block to replace that other Memphis OFC is even better. IIRC it cost me 28 bucks on prime for those sky high 4 channel set. I had bought some other other ones but the RCA head was too big to plug into the DEH-80PRS. Those sky high worked perfectly.
I have quite a bit of Stinger Zero Noise RCAs from a large purchase in the past.Ive always seemed to go back to those for some reason. I been looking at some Dayton RCAs that I may try out in a bit.They look well shielded and heavy duty to hold up a while
Those RCAs look pretty nice for the coin.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
So i got a 1.5ft Stinger 9000 series rca and i cant get none of the four twist locks to come off. I have had sets of these before and not had...
Bass so loud it HZ
Bass so loud it HZ
IN, United States
audiobaun
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
