RE Audio XXX 12" sealed box recommendations
Its peaky. Hits real loud then just drops off. It almost sounds like it hits backwards. Not the best way to describe it but I can't think of another way to say it. I really just want a flat response from as low as I can (say 20-25) to like 80. I'm not sure If this is possible in any box but id be happy with a flatter response across a broader range than It hits now.
I've recently discovered a video of a 12 In a 4th order bandpass box that hit pretty flat in that range but I have no experience with them. Any advice on those would be appreciated too.
You're going to want to do something like 2.25-2.5ft^3 with a 25-26hz tuning. Since the Fs is so low(21hz), tuning even at 33hz is going to give you a big peak that will just seem to drop off on either side(mainly lower). Going with a slightly smaller box and a lower tuning will hurt efficiency, but throw 3kw at it and you should get some good bass out of it. I don't expect it to play very well up to 80hz though.
A Link would be very helpful. Id be interested in taking a look at some gear
213
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
337
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
teptepley1
teptepley1
Lake county, OH
teptepley1
