Rear speakers not working, help!
  • 4
GabeDahlinghaus
CarAudio.com Newbie
9
I installed an aftermarket stereo into a 2007 Honda Accord. It powers on and the front speakers work, but the rear speakers are silent. I’m not sure if it has to do with a factory amplifier or something like that. And I made sure all the connections were correct and secure. Please help!!
very unlikely a factory amp issue otherwise the fronts wouldnt work either. double check the wiring schematic to find what the RR + and - and LR + and - wires are to connect to the harness. You probably have a couple of them switched up
I’ll check on it. That’s most likely the issue. Thanks bro.
this is of course assuming that you have a conventional aftermarket head unit hooked up to an adapter molex plug wire harness directly, no external amp or anything like that
All wires are correct; rear speakers still don’t work. I even reconnected the rear speaker wires and no sound. The speakers themselves worked fine right before I installed the after market stereo.
what about the fade? or even an on/off setting for the rear speakers? can you test them with another speaker like a small home audio speaker?
I set the fade to mostly rear speakers and no sound. I already tested the rear speaker wire outputs with a test speaker and there was sound from the test speaker.
Pull each speaker in the rear and test with an Ohm meter/DMM and see what the value is.If they are 2 ohm stock speakers they should read around 1.9-2.3 ohms. Same area for a 4 ohm speaker..3.9- 4.3 ohms. If readings are all over the place ,,speakers are no good/ blown
Ok, I’ll check back with you once I get the results.
you can also leave the speakers in the rear deck and test them without speaker wires connected to them
I tested the rear speakers with a multimeter and I didn’t get a reading, does this mean they are dead?
Sounds like an open circuit so yes... if you don't trust the reading use a 9v battery on the speaker leads and if it won't move they're toast. (coil or tinsel leads failed)
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
997
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
3K
I will check when I’m off work and get back with you. The current speakers are coaxial 2 way, it has the tweeter speaker in the middle. I posted a...
7
GabeDahlinghaus
CarAudio.com Newbie
GabeDahlinghaus
GabeDahlinghaus
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
