Rearview camera delay off
  • 2
chawski
Ive only ever driven a car with a manual tranny, and never realized until I installed a rear camera that I pretty much always pull out of reverse and into neutral while im still backing up.
Id like to make some type of delay to keep the rear view camera on for maybe 5ish seconds after coming out of reverse. I was thinking maybe a small capacitor on the trigger wire? Would that work? any other better ideas would be appreciated!
Hi, I installed a new Kenwood dnr476s head unit along with idatalink maestro Rr, the HRNI1, the HU-Ken1, and the nav1 adapter. It works well...
It only works when the car is in reverse. Also, some units have trigger options in the settings menu.
521
Try to reset again and if that doesn't work, try updating the firmware. To update the firmware for Alpine X800D, you can follow the instructions...
How positive are you that the reverse camera power supply was spliced in with a reverse light wire? If you used one of those blue wire splicers...
That looks like it can work for backup cam for sure, thanks
915
chawski
chawski
Philadelphia
chawski
Brendon Jenness
    May 8, 2024
    May 8, 2024
