Recommendation for my Kicker 11VS12L72
  • 3
RobNyc
I just bought this sub and looking for a good amp recommendation.
Kicker VS12L7 12 Inch 750W Solo Baric L7 Single Subwoofer Box 2 Ohm [11VS12L72]
SKU: 11VS12L72-N
RMS Power Handling (Watts): 750
Peak Power Handling (Watts): 1500
Subwoofer Size: 12 Inch
Basket Material: Cast Aluminum
Cone Material: SoloKon
Frequency Response: 20-100 (Hz)
Hole Cutout Diameter: 11-1/16"
Impedance: Dual 4 Ohm
Mounting Depth: 6-11/16"
Recommended Ported Box Cubic FT: 1.75 - 3.25 (CU. FT)
Recommended Sealed Box Cubic FT: .88 - 2.0 (CU. FT)
Sensitivity (dB): 88.6
Surround Material: Santoprene Rubber
Final Impedance: 2 Ohms
Width: 18-3/4"
Height: 16"
Depth One: 18"
Depth Two: 14-11/16"
I chatted with someone from HalfPriceCarAudio website where this sub was purchased at.
They said this sub is a dual 4 ohm wired = final 2 ohm
"that box has a dual 4 woofer wired down to a 2 ohm load. So you want an amp that is 2 Ohm stable"
So I would require a 1000W RMS @ 2-ohm stable amp correct?
I really don't know much about this and would like to hear a few amps recommendations for daily use and that last.
I would like to look at a few from different price ranges and avoid the cheap stuff that will not last or heat up.
I have a Cadillac STS 2006 V6 w/ Factory Navigation, had a guy do the wiring stuff in the back where the factory amp is located and there the conenctions for the amp are ready. Ground, Remote, and Volt i think it is. Subwoofer is already sitting in my trunk ready for its amp.
Thanks
I've been researching and researching
I came down to these that are in my budget and they come with a remote //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Soundstream DTR1.1700D (Amazon expensive) but on another site its on sale for $188
1100 Watts RMS x 1 @ 2 ohms
-Hifonics BRZ1200D (900 Watts RMS @ 2ohm)
-Hifonics BRZ1700D
Audiosavings Amazon store
Same price $179 (Not including my gift certificate)
- Hifonics Hfi1500d
4 ohms: 500 watts x 1 chan. 2 ohms: 1000 watts x 1 chan. 1 ohms: 1500 watts x 1 chan.
- Hifonics Brutus Brz1200
4 ohms: 450 watts x 1 chan 2 ohms: 900 watts x 1 chan. 1 ohm: 1200 watts x 1 chan.
$199
- Us Amps Xt V3 Series Xt4000de
$213
- Hifonics Hfi2000d
4 ohms: 650 watts x 1 chan. 2 ohms: 1300 watts x 1 chan. 1 ohms: 2000 watts x 1 chan.
$230
- Re Audio Xt V3 Series Xt4000de
$249
- Hifonics Brutus Brz1700.1
4 ohms: 600 watts x 1 chan. 2 ohms: 1200 watts x 1 chan. 1 ohm: 1700 watts x 1 chan.
Hope you guys can help me make the right decision because this is it.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
Yeah, not sure if they meant this, but spend some time going through here...
23
3K
roger that, just got one from sonic electronix for $189. thanks for the help
18
SQ yes but with a low Fs. 7.5" VC and a 3500 watt RMS rated capability, it’s a beast of a performer. Not well known in the car audio circuit, but...
RobNyc
RobNyc
New York, NY
RobNyc
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
