Which brutus amp should i get
finisher1
I have 2 12 inch kicker l7 dual 4ohm. Im planning on getting a hifonics brutus amp for them but dont know which one would be best and at what ohm should i load them on. Also are the brutus elite amps cea aproved because i havnt seen anywhere where it says they are?
You will be safe with the BRZ line. For those kickers you will wire each sub in parallel to itself to achieve 2ohm per woofer, then parallel again for 1 ohm
I'm not sure what L7's are rated for but you'll want either this
Hifonics Brutus BRZ1200.1D 1200W Mono D Amplifier : BRZ12001D : $188.95 : VMInnovations.com
or this
Hifonics Brutus BRZ1700.1D Class D Mono Amplifier : BRZ17001D : $237.95 : VMInnovations.com
Either of which will require you to do the Big 3 (if you don't know what it is search the electrical section; it's stickied) and possibly a rear battery. I'm not sure if there are any active promo codes right now
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
295
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
303
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
362
finisher1
finisher1
San Diego, CA
RobNyc
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
