SOLD Reduced Prices - High End Passive Xovers - DLS midrange and CDT 2 way
  • 3
BassAddictJ
FL
Pics on original thread:
High End Passive Xovers - CDT and DLS
DLS midrange passives for the IR 3 midrange spakers: 500Hz - 5kHz. 12dB slope.
Made for the Iridium component set ($1000 3 way set). These passives can also be wired in parallel with 2 way passives, as shown by the DLS wiring diagram for these units (page 3).
http://dls.se/files/185/2/Man_IR_spkrs06_eng.pdf
30 shipped. you will not find quality midrange passives cheaper....
CDT SatNet 560 2 way passives with an extra tweeter output: Tweeters are 3.7kHz and up at a 24db slope. There is an aditional tweeter output for "Imaging". This is the same cutoff but at -3db output.
The woofer output has a swtich for 6.5'' and 5.25'' woofers. The 6.5 switch plays the woofer to 3kHz, and the 5.25 switch plays the woofer up to 4khz. All these at a 6db slope. according to CDT tech support.
These passives are at the cheapest $150 shipped online. I want 45 shipped.
also a few other pics on the original thread. link for that is located near the top of the first post of this thread
now buy this ish~!
Are you sure you're not just going so fast, that the speed of sound is having trouble keeping up? That's barely using anything. You don't need...
660
Damn this is comical. Finally got a hold of someone there via phone and they are not taking RMA's right now,lol. The switchover to the new system...
33
7K
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
118
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
702
BassAddictJ
BassAddictJ
FL
BassAddictJ
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
