Reg Cab help
  • 4
bj5593
New here so bear with me current setup is a audiopipe acpl 1800.1d on 2 orion xtr 15 2015 models 0 ga knuconcepz in a 94 dodge ram 2500 reg cab with the 5.9 diesel with dual 220amp alts 2 1400 ca interstate fleet and farm the box is where the center seat would be just removed it and it is a prefab box ported. I was looking to get it louder i dont have the space to build a custom box larger than the prefab anybody got any ideas on what my new setup could be ? Id like to get in the 150 db range mids and highs are taken care of jl 600/6 on 6 6x9s
Box in truck now is 24inchs wide 46inches long 21 inches high the only thing that can be changed of those is the height but only add a few inches
My suggestion would be talk to a local audio dealer that actually competes with the subs that he is selling . My local Incrimanator Audio dealer(Bills Wholesale in Clarksville Tn ) has the trophies to back up what he is selling . The last time I was in there I ran into a customer that was pulling over 150 in a reg cab 1500 Dodge . I personally think your looking at spending 2000 to 4000 to reach that level on new equipment . I have also seen some sweet deals in caraudio classifieds too .... so good luck on your build .
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
bj5593
bj5593
wingate nc
DaytonLax14
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
