Mitsubishi reverse camera adapter 10 pin
  • 1
xpusostomos1
CarAudio.com Newbie
I bought a 2023 Mitsubishi Strada, known in most parts of the world as a Triton. Although it's 2023 it hasn't changed for a few years and this head unit has been sold here for several years with it. Probably next year Mitsubishi will make an all new model. Anyway I bought a 3rd party head unit that came with a Mitsubishi wiring loom supposedly would suit Mitsubishi Triton. The grey reverse camera socket on the loom is 8 pin which as I understand it is quite common for Mitsubishis. However the cream color factory reverse cam plug is 10 pin. (See pic attached). I can't find anything much online about this plug or how to adapt it. I see on ebay various sellers are selling 10 pin plugs to RCA, which from the pics could plausibly be the same plug, however it's a male plug anyway, and I'd need a female socket to be of any use. Also I looked at the pinout on them, and it seemed different.
1. Is this plug familiar to anyone?
2. Anyone know of any adapters for it?
3. If I could somehow get the pins into the right holes, would it likely work?
4. If I can't buy a ready adapter, is there any procedure or parts that would allow me to construct one?
The other problem is there is a pink color USB cable, which is a larger size than will fit directly into the head unit.
CASSETTES BRO, you know it. Those wirings are straight up giraffe neckin. 79 cars had lot of electronics for carburetors. Know your poopie...
19
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
Hi, I installed a new Kenwood dnr476s head unit along with idatalink maestro Rr, the HRNI1, the HU-Ken1, and the nav1 adapter. It works well...
It only works when the car is in reverse. Also, some units have trigger options in the settings menu.
576
xpusostomos1
CarAudio.com Newbie
xpusostomos1
Philippines
xpusostomos1
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
