RELAY's for fan
yes but diode isolate them so the fans dont backfeed noise into the epic.
85 fused 12v
86 ground
87 remote wire/ant from headunit
30 output to ur fans and epic
you dont need a 5 pin 4 is all you need.... how this helps you...
Cant a drug smuggler afford to pay professional installers?
stalker. (loser)go take your illegal immigration rage back to the thunder dome. u seem a bit desperate to get your point (if any) across. so sit in your underwear drink a bud-wiser or moonshine keep complaining on problems you have over in the U.S and do nothing about it but whine.you= no action all talk. by the way
i don't pay someone to do my hobby
stalker. (loser)go take your illegal immigration rage back to the thunder dome. u seem a bit desperate to get your point (if any) across. so sit in your underwear drink a bud-wiser or moonshine keep complaining on problems you have over in the U.S and do nothing about it but whine.you= no action all talk. by the wayi don't pay someone to do my hobby
Seems the person raging here is you. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
skip the diodes they arent needed, diodes areonly needed to stop the back flow of VOLTAGE to filter out ac ripple you will need a capacitor...either way run the remote wire leading to the amp as far from the rca's of the amp for the mids and highs as possible or cross them at 90 degrees and you will be fine.
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
4
cartablanca
cartablanca
Culiacan,Sinaloa
FenixAudio
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
