REM Wire
  • 2
BrockJJJ
CarAudio.com Newbie
6
Utah
Hello, I'm installing a second amp into my truck. Can I tap into the REM or would that not work? I have separate wire ran for power and ground so I just need to know if I can use a splice to tap into the REM or how I would go about getting it
Yes.. For a second amplifier you can use another 16-12ga single wire from the 1st amplifiers remote wire location and use a second wire to go to the second amplifiers remote location.Piggy-back off it so to speak. Adding a 3rd amplifier or more.. I recommend a relay such as a 40 amp. Two amps should be just fine
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
129
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
641
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
920
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
894
BrockJJJ
CarAudio.com Newbie
BrockJJJ
Utah
audiobaun
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
