Remote Bass Controller w/ Multi Channel Amp ?????
  • 1
bbrodin
Hello, new to the world of custom car audio and was curious if it was possible to add a remote bass controller (or a gain controller by any other name) for a sub to a 4 channel amp powering the sub and component speakers? This would be optimum as it would save money and space (single cab truck). Thanks yall.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
624
I'm not familiar with Vertigo amplifiers. If they have a master-slave setting, you only need one gain. otherwise, @dragon.breath nailed it.
991
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
bbrodin
bbrodin
Roanoke, VA
bbrodin
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
