remote start/ keyless entry issues
explorer2
usa
I have an avital remote start system that I'm having problems with. I have two remotes, 1 has never worked, and the other has been slowly going downhill. DO these commonly go bad? I replaced the batteries but the lock and unlock do not work at all, start works sometimes from short distances.
nope regular 3 button remotes. I'm very sure its not the brain as it still starts sometimes and the doors still unlock when I turn the key off.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
680
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
explorer2
explorer2
usa
AsianInvasian42
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
