replaced fuse, now i have engine whine
  • 5
maljr1980
Replaced a fuse under the hood, now I have engine for the first time after 2 years of wiring. Makes no sense, re routed RCA, grounded RCA to head unit, wrapped wire around rcas an amp the same easy as an installer friend of mine suggested. Ground is good, sanded to bare metal, grounded to chassis. Won't go away, I'm about to tear everything out and rewire the whole thing. Anyway wtf happened?
Some one told me to run a wire from my cdplayer ground to my amp ground. Will that work?
It will improve the HU ground drastically but if it resulted from the power wire fuse I wouldn't think so...
What happened that caused you to need to replace the fuse?
I'm not sure, I have this digital fuse thing that lights up and displays how many amps and volts are going through it, I noticed all my amps going into protect so I went under the hood and it wasn't working. Took it all apart and put back together and it started working again, current flowing back to my power cell again, that's when the ground loop started, I'm totally stumped
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
maljr1980
maljr1980
frederick co
maljr1980
    Jun 1, 2024
    May 31, 2024
