Replaced head unit - Sub constant flexing tone
  • 2
Just switched my head unit for a different one. It had a sirius head unit with no cd player so I switched it out for one that did.
I matched all the wires up and even re checked this this morning. I'm at a loss here.
The Problem:
- When turning on the head unit regardless of "radio" / "usb" / "cd" / "ipod" etc, you hear the sub kick on and its just sitting there pulsating and I want to say there is a tone on it but its so low I can't hardly hear it but you can tell its there and annoying.
*This is with the head unit "sub volume" turned to 0 and "bass" turned to 0. Regardless of what I do it still does it. It still pounds and plays bass just fine but the tone / constant sub movement is driving me crazy.
I changed nothing other than the head unit, so not sure what went wrong.
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
Matthew Tanner
Matthew Tanner
Cadiz, Kentucky, United States
Matthew Tanner
