**** so many choices guys... wont i **** up my suspension if i lower my truck? the only...
These are the thoughs i had in mind.
-20's-
Extreme Body Kit
Rollpan
-22's-
Just the rollpan
I heard that 22's on a blazer with 35 series tire will rub a little..
1st Suspension questions...
What does you suspension do? it moves up and down....
A suspension has limits, if you lower it or raise it to the point of those limits, you may suffer some ride loss...
By using kits like Belltech it repositions the rim mount (Front-Spindle and Rear- Axle) higher into the wheel wells, this lowering the vehicle...
The rear is where people usually have issues... They drop the rear end so far that the frame actually sits down on the axle tubes.... It it creates a really bumpy ride... It usually takes 5-7+ inches of drop to do this with a big rim...
To fix this, you use a C-Notch.. It gives you 2-3 more inches of travel or a Bridge notch that can give you as many as needed... You can lay out on 24s, if you build it right...
No talk about the front end... There are several ways to do this, each increasingly expensive, but each better, less ride loss...
1st. Heat the Coils with a cuttin torch till the front end drops... Its Free, but worst ride ever..
2nd Drop coils (u can get them in 1-2 or inch drops)
3rd Drop Spindles I think Belltech only makes them in a 3" drop...
You can use the 2nd and 3rd methods together for a bigger drop...
(3 inch spring 3 inch spindle for a 6 inch drop) I sould not go any lower than 3-5...
Now talk about Rims sizes...
With 20s and 35 series tires, they will not rub even with a 6" Drop front and rear...
With 22s, I find that they can rub on the front when turning, even if not lowered... If you drop a truck on 22s, you as asking for problems, unless you tub the front end....
You can do anything and make it work, with the effort and money...
Whats it worth to you?
I would pick one of the following setups....
22"s front and rear no drop (my last favorite option, kinda ghetto IMHO)
Ohh, lets thow some Bling on and call it Custom...
Big rims or anyrims, No drop and a body kit looks even more gay....
20's Front 22s Rear, slight drop say 3" You can still get the body kit and rollpan and not drag it off on normally decent streets...
20s all the way around, more of a drop, up to say 5" still use body kit and rollpan....
Just some of my opinions, hope they help atleast a bit... I know how it is.... You only make money so fast, you want to build a ride that you like as well as one that catches looks and nods as you roll though the spot....
I started out with many of the same questions....
