Ring terminals...how do i use em'??
Get a drill bit and hammer it into the terminal with the wire in. Then finish off by just hammering like crazy.
I am pretty sure that a center punch would be a much better choice than a drill bit. Drill bits are not engineered to withstand hammering.
I used to do this, but had one slip. now I crimp while solder
I did my entire race car main feed wire(1/0) this way
and the only way they can slip out is if the person doesnt get the wire in
deep enough...I tested the strenth and I could not pull it apart
and my race car vibrates like JennaJamasons vibrator
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
754
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Donks
Donks
CO, Ohio
Ignatowski
