Rockford Power DVC's vs. Eclipse 88100.4
  • Thread starter <InfinityPerfect>
  • Start date
  • Replies 0
  • Views 2K
    Participant list
<InfinityPerfect>
Guest
I am caught between 2 awesome deals here. I can get either setup for really cheap! here it is, should I get:
A Eclipse Aluminum 88100.4 SVC or
A pair (2) Older Rockford Power DVC's?
I'm powering them with a PPI 2360.
I've got a Lincoln Continent(Insulated like mad) so SPL is just as important as SQ.
Thanks
11
558
The surprise wasn’t that they didn’t offer one…it’s how much engineering went into making it easily replaceable, and then not offering one. Maybe...
9
Thanks ya. Just pulled the trigger on the 1500BDCP because of the constant power that RF developed to help with the ohm rise.
11
958
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Guest
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
