Running new speaker wire
  • Thread starter <Muff DVR>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<Muff DVR>
Guest
Changing out stock head and speakers with blaupunkt. Also adding a changer. Would it improve sound quality if I ran new speaker wire around too? Or, is stock wire fine?
There is really no audible difference between wiring. If you plan on amplifying your midrange speakers, then I would run new wires, otherwise, you should be fine with the stock wire.
Take it easy,
-zane
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
495
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
4
Guest
zane
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
