cd player *****
  • 2
BigBoi
ok, i have bought a new jensen cd player...and i've only had it about 3 months, i got my subs and everything hooked up, they were hitting hard too, then all a sudden, all the sound in my car just stop. i have no clue what happened, but i'm positive it's something inside the cd player, because if i take another stereo and put it in, the factory speakers work but not the subs....what happened?!
[ 12-22-2001: Message edited by: BigBoi ]
Firstly a little more info about what happened. You say that when you install a new head unit (HU) that everything works but the subs. Is there a sub pre-out on the other HU? Also, what happens to your old HU when you try to power it up?
Could be a fuse, could be the wiring, could be an internal HU amp/pre-amp.
Take it easy,
-zane
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
381
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
BigBoi
BigBoi
Ladson,SC
zane
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
