SA-12 sub orientation and box size
  • 4
MobileLightning
I plan to install a couple SA-12s within the next couple weeks. I only have the room for 2ea. "1 cubic foot" sealed boxes. Also, the subs will be firing straight up at the hatchback.
Is this box too small? Site recommends 1 cube.
Does firing up degrade sub performance?
Thanks,
J
Thanks,
J
Yes. It is too small.
Manufacturers recommend the minimum amount usually. Is it 1 Cu.Ft. in total or each? Go with 10s instead. I'm not sure 1 Cu.Ft in total net would be enough even for 2 SA-10s.
I personally fire rear due to space restraints related to very sharply reclined fixed rear seats.
I would recommend a single SA-10 in a Ported 1.5CuFt. @33-35Hz enclosure. That should get you going.
Dayton HO 10s do well in a sealed enclosure in 1.0 ,and carry a 5 year warranty that most subs only carry a 1 year warranty.Beefy 600 rms tens and can take a bit more over the RMS of clean power as Ive experienced of a true clean 750 each on the daily on a pair on my first generation American Bass VFL 4480.1 d
214
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
547
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
576
MobileLightning
MobileLightning
Mobile, AL
audiobaun
