Screws for box
Yes predrill. And I'm with heresy I use bolts and t nuts also. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can't see the t-buts because they are underneath the face of the board where the subs sit and the bolts look no worse than screw heads if not completely the same.
Originally posted by Jon403 I'm mounting 3 10w6 jls on the front of a box made of 3/4" MDF and I was wondering what size screws I should use? Does it matter if they go through the MDF? Should I predrill the holes for the screws?
3/4" - any size.
No.
Yes.
Bolts and t-nuts are the way to go //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
- Steve
Sorry I don't really understand the t-nut thing, its sounds like a great idea so could someone explain it to me. The bolt you use has little progs by the head right? And so do you have the head on the inside of the box with the nut on the outside? Any help is appreciated, pictures would be great also.
Nevermind I think i got it. Tell me if this is right. So it is a nut with prongs on it. And you get it stuck to the inside side of the mdf where the pre drilled hole is, then you can just thread the bolt through and tighten it down and this leads to easy installation and removal? What length and diameter bolts/nuts should I use?
Usually I keep it to the length of the bolts to about the thickness of the material they are going through, sometimes a little shorter. The diameter of the bolts should be about the same diameter of the holes used to mount the subs. Notice how I use the word "about" a lot. This isn't a science(at least not this part); as long as air isn't able to get passed the bolts/tnuts, it works.
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
9
724
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
5
  • Locked
That MRD is a good series of amps ...i may have some extra accesories if you havent found them
8
3K
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
186
Jon403
Jon403
Fairfield, CT
Heresy
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
