help on box size
  • 2
I got 2 12" sound stream tarantulas wich handles a 1000w each with a 2000watt amp I need a good box that will hit real hard i want people to feel me coming down the road any suggestions i never tried a wooden box always went with the plexi glass boxs so can any one help me on the box size and weather i should port it or seal it please help also its for a 92 nissan sentra
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
745
bumpin_nissan
bumpin_nissan
versailles missouri
beachboy016
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
