SD port with FOLDER-based browsing and 5V preouts?
  • 6
explain why uou need an SD port? get a USB capable HU then you can simply run over to bestbuy and get a memory card expander via USB... done deal. my 9886 is very fast using the USB
Get a cheap headunit that has a SD card slot then get a clarion EQS746 for your 5volt preouts. Finding a HU that has true 5v preouts is going to be expensive, this way is much cheaper.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
843
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
991
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
c_hayhurst
c_hayhurst
Columbus, Ohio
mossberg385t
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
