I've been spending a while searching for the "good enough.. or slightly better than I need" wiring for my installation I will be doing myself.
Basically the setup is coming from a Pioneer AVH-P4100DVD Headunit with 3 RCA outputs (RCA for Fronts, RCA for Rears, and RCA for Subs).
I am using just ONE 4-channel amp.
I am putting in 2 door speakers (with component tweeters).
And lastly I am putting in one 10 Inch JL sub.
As I'm pricing wiring,.. it's almost half or more what a pro install would cost.. so I need help here.
I want 4 gauge "power" cable thickness (with appropriate fuse.. and quality).
I want 3 sets of RCA cables long enough to reach from headunit to the hatchback of the 350z. (I am going to run the "rear" RCA's anyway.. just in case I decide to put some rears in one day and it will save a lot of time.
One of the RCA cables I want the Remote wire to be twisted or connected with it,.. just be one less wire to have to run.
Of course known quality RCA's.
Speaker wire,.. I think 12 Gauge is about 2 gauge more than I need.. but might as well. So I need enough of 12 Gauge quality speaker wire (marked for polarity) to run from a 4channel amp to my doors (amp will be in trunk).. and to sub (sub will be 6-8 foot from amp approx.. but don't know how many twists and ups and downs running it will take.)
Also,.. What are the 'easiest' secure connectors to use to splice wire together, and to put terminals on?
I heard of heat shrink connectors.. are these any good? Are they easier or better than Crimp connectors? I'll pay a few more bucks for ease of use,.. so whatever connectors all this wire will need and some extra for wire I cut and have to splice.. I know I'll have to splice the remote wire.
Anything I'm forgetting for the complete install?
In my searches,.. I'm coming up like $150 for wire.. and that seems high, but the last thing I want to do is wire this up and it have wiring issues, whine,.. length problems.. etc.
I've done my homework, I see all the "kits".. but no kit I've found meets all the needs I have here for this triple RCA out from headunit to amp.. power, fuse, terminal connector, ground wires, speaker wires, etc.
Appreciate any help in this area.
