Searching for speakers.
You're going to have to look at home speakers, maybe some pro-audio speakers. That's probably going to mean 8 ohms.
Agreed. I cant think of any 10" in car audio Like that.. But deff in Home Theater/Audio.
I'm curious why? You would certainly be extremely limited on options. You could fit a 6.5 or even a 6x9 and a tweeter in the space a 10" speaker takes. Even if this was something like a sub enclosure, you could make a 10" face that would bolt in, and make a 6.5" and a tweeter fit.
He is limited even the options I came up with are 7s mounted in a 10" mounting ring.
Is there a good 10" round 3/4 way car speaker on the market made by anyone.
10" and 8" available on Amazon:
Not sure hot to define 'good' so its for you to research or watch youtube videos:
Wow!! LOL..
  • Locked
If you’re going to spend that kind of money, you should be looking at Beryllium domes too. Like the ScanSpeak Illuminator D3004/6040-00 Beryllium...
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
159
It also lowers the amps efficiency and raises the current draw.
5
334
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
472
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
Raa
CarAudio.com Newbie
Raa
U S
audiobaun
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
