Second Battery Questions
SBFandy
Hey guys whatsup.
I recently picked up a stinger spv 70 battery. Before attempt to install it I would like to know the Correct way of doing it. Any tips that you have for me are great! My stock battery isnt anything amazing if that means anything. Are relays a good option? LET ME KNOW! HELP ME OUT ! haha just want to do this right! thanks ! : ))
Hey guys whatsup. I recently picked up a stinger spv 70 battery. Before attempt to install it I would like to know the Correct way of doing it. Any tips that you have for me are great! My stock battery isnt anything amazing if that means anything. Are relays a good option? LET ME KNOW! HELP ME OUT ! haha just want to do this right! thanks ! : ))
just run your power wire from front battery to back battery. and back battery to the amp.
Example:
[front batt]+_________+[rear batt]+_________+{AMP}
also ground the rear batt to body of car/ chasis or whatever
Example:
Is that going to be harsh on my stock alternator?
it should be that bad on it honestly. i had 3 batts and a stock alt before and it did fine... Do you have the big 3 done?
It will be done yeah
---------- Post added at 09:53 PM ---------- Previous post was at 09:53 PM ----------
Na bro your alternator will be fine, Just make sure you fuse the power wire 12in or less from each battery. make sure you secure it so it doesn't tip over
Thanks for the help man!
ok that will help with more current flow. and no your stock alt will be ok. what kind of amp do you have?
Connecting two different battery's specially diff ages of battery's or diff sizes isnt good for anything.....
ive done it..... never had a problem out of any batteries ive used being mismatched. no im not telling him to do this but ive had good luck with it as well as other people i know and on the forum. im not completely matching batts right now and the batts are fine and voltage stays above 13.7v at full tilt while im sitting at idle.
two alpine m1000 rms
hm... usually when you get more then 1000rms is when up grades get heavier. i would do the big 3, and get the 2nd battery in, run it and test voltage while playing and see where your at. your more and likely not going to get 1k from each after rise so you may be fine with the extra batt and big 3
Test my voltage for what? what would be an unsafe voltage?
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
9K
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
104
SBFandy
SBFandy
Wisconsin
JoeK
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
