Second battery
  • 2
1SSB
All, I am new to this forum and wanted some advice on how to hook up a second battery as I have been told I have a lack of power.
My system is a Orion hcca 12.4 powered by Orion D5000 amp, Focal and Hifonics doors speakers powered by Pioneer GM-D8604 amp, LC2i for bass roll of as it's a stock head unit and power is stock battery. Car is BMW e90
I have been told I don't have enough power as my sub cuts out at high volume which I believe is the case however my door speakers do not cut out and The ground is perfect.
I am planning on wiring a 0 gauge wire from the aleternator to the second battery and keeping the batteries separate.
My question is what battery would you recommend for my system and would I require a battery isolator so that the secound battery will not be degrading by the existing car battery.
My budget is around £300
Could someone advise me please, thanks in advance.
When it drops below 12v its cuts out for about 5-10secs then comes back on but my other amp stays on, no protect lights come on. When i turn the gain down i can turn the volune up more so i believe theres not enough power?
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
9K
361
1SSB
1SSB
Birmingham UK
1SSB
