Series/Parallel Wiring Combination Possible- 4 Channel Amp?
  • 2
Synoptic 12
CarAudio.com Newbie
I’m trying to structure a system that may be considered non typical. However, I am seeking some information regarding the following:
1.) I’m using 2 (3.5) Infinity Kappa Perfect: impedance 3.5 ohm, Sensitivity 88dB, Frequency Response150Hz – 10KHz (75 RMS,300 peak) (DASH)
2.) Installing the Cerwin Vega (4 x 10) H7410 in rear panel: Peak: 640 watts per pair / 320 watts each
RMS: 100 watts per pair / 50 watts each, Sensitivity 93 Db > Frequency response: 75 – 20000 Hz (REAR)
3.) Using an Orion HCCA 1000.4 amplifier to push the speakers. Can I configure the speakers in a series/parallel combination > ie. Use parallel wiring up front (3.5) to obtain 2 ohm (Or just leave at 4 ohm) uncertain as yet? And, can I configure the (Rear) 4 x 10 in series to obtain 8 ohm, allowing the amp to run cooler?
4.) Whether or not this structure has been used in the past is unknown to me. I believe that there could possibly me more staging by using a fader control on the head unit, again uncertain.
5.) Are there any benefits (pros or cons) as using a 2 or 4 ohm load in front while powering the rear at 8 ohm? Please elaborate.
Would sensitivity as well as frequency response play a part in using a combination- Series/Parallel and if so what? I would also like to add another amp (mono) to drive a 10” sub-woofer. Can any provide an analysis as to the aforesaid. Any and all input is most appreciated.
Youre using a 4x10 speaker? Those things sound horrible. You have a 4 channel amp, why would you wire the front and rears together? Also, that amp will blow those speakers if you turn it up.
What exactly are you trying to do and in what car? Pairing a 3.5 and 4x10 with a sub will sound like **** quite honestly with a huge hole where the mid bass is supposed to be.
I have a pair of telza audio 12" subs for sale great condition never ran over the 1k RMS rating. I'm willing to ship just need to know a area so I...
You can stream videos off of youtube. There are some videos of Japan, and some nature videos that are awesome to watch, and show off the...
5
213
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
6
Synoptic 12
CarAudio.com Newbie
Synoptic 12
Talontsi90
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
